Huemann
I've been trying to solve an issue on my truck, 1989 Ford Ranger XLT 2.3l Manual Transmission, and I've just found myself confused. I believed I found a short, I took the negative cable off and with my multimeter reading mA put the ground on the post and the positive on the cable. Got a reading of 3.4 something.
Went through the process of pulling fuses, found it was the alternator power, and narrowed it down to the alternator itself. I read that if the alternator has a short in it, there would be smoke, obvious visible signs, and I haven't had any problems, truck is mostly running fine.
I'm wondering if this is a normal reading. The way my truck is wired, the positive battery cable runs to the starter relay, with the same post holding the power to the power distributor box. There's nothing stopping the alternator from pulling power. Thought I had my starter relay wired wrong but I confirmed it with my wiring diagram.
If this is normal, wouldn't this drain the battery? It's not been dead for me.
Attached files of the wiring diagram, and a closeup of the starter relay wiring. The RED/LT BLU goes to the ignition switch, and the second connection (No color, it's black) coming off the input of the switch goes to power the power distributor box.
