Alternator fuse keeps blowing
notaprob
Wilmington, N.C.
1994 Ford Ranger 4.0. I'm having trouble with the alternator fuse blowing. It's the number 16, 15amp fuse in the power distribution box under the hood. I had the battery tested, and the alternator bench tested. Both are good. I had to have the alternator bench tested because it would not read on the handheld. I tested it for a short by connecting an ohm meter to the yellow/ white wire from the pig tail of the alternator to the ground and could not get it to ground. It ohm's out from the pig tail to the fuse box, so it has connection. The alternator begins to charge normally when I replace ther fuse but blows when I drive it for a few minutes. I'm thinking about running a jumper wire to see if it solves the problem. Have any other ideas?
I would unplug the alternator harness and carefully inspect it all the way to the fuse box. It may have rubbed through somewhere that you can't see.
Just to confirm, the wire goes straight from the fuse, through a connector, and then to the alternator?
I also noticed on the drive to work this morning, when it gets to 3000rpm the voltage gauge would drop and battery light would turn on. As soon as the rpm drop below 3000rpm the battery light would turn off and the gage will return to normal. I ended up revving it to 4000rpm and then the fuse blew again. I will dive into taking apart the harness to see if I can find a short. Will a short in the charging cable from the alternator cause the fuse to blow also?
I believe that is what the fuse is for. The fuse is not for the larger output wire of the alternator that actually charges the battery, its a smaller fuse for the controls of the alternator.
The charging system is working now. I replaced the 15amp fuse 2x and then it stopped blowing. However, the voltage would drop when the engine got up to 3000rpm. I had to drive it to work for a few days like that and it eventually got worse to where it would stop charging at 2000 then 1500rpm. Yesterday, I was checking the wires again with the volt meter and everything checked out like it should. In the middle of testing the voltage and revving the engine, the alternator stopped working all together. I took it to the autoparts store to have them check it for the third time and they confirmed it was bad. I got the lifetime warranty 2 years ago so I was able to swap it out under warranty. Everything is working great now and no light. My question is, this is the 3rd alternator in 2 years. Is it the duralst alternator not holding up or could there be a short causing the regulator to go bad? I've looked the wiring harness over many times and there does not seem to be any damage. I guess the next option is to unwrap the harness to get a better look at the wire.
always get the lifetime warranty.
and get used to changing stuff if you will keep it long term.
i used to eat at least one water pump a year with my windsors in my ranger...alternators and fuel pumps are a pia....
but i was driving a ton of miles too.
Higher rpm problems with a alternator usually point to worn out brushes.
These rebuild places do the bare minimum to their rebuilds, and then send them out the door. You would think for what you pay, they have a minimum requirement, like replacing the brushes, new regulator and diode pack, new bearings, besides checking everything to see if it's good. Sadly, this is not the case. Once you get tired of taking the lifetime rebuilds back, and take one apart, you can see the evidence. Looks good on the outside, old on the inside.
