1chance
- May 19, 2012
- Automatic
I have a 95 ranger 4x4 with a 6" duff stage stage 3 lift. It continues to pull to the right with a perfect alignment. Truck is at trails west here in Ohio, they work on lifted trucks and install lifts so they know there stuff. We have Cher the following: brakes, bearings, thrust and tires. Known problems: power steering pump howling on start up and constant hum at some stops. Could this be a valve in the steering box causing this problem? Anyone else have this problem?
