alcoa questions
dixie_boysles
MA, NC
how hard would it be to get these to look like new again? i can get them for a
good price, but i juswant to know if it would be easy to clean up? i know somomeon who could sandblast them and then i know somone who could clearcoat them after i get them cleaned up.... but ive been told that sandblsting will leave pits! Could i use some good paint stripper to remove clearcaot, then polish real good? any ideas?
All I know is that they are made in Cleveland Ohio (my dad works at the Lafayette, IN plant) and tells me all this but those rims will last you forever.
My best bet would be to start with mothers Mag Polish. and then after they are a good as they will be then go ahead a clear coat them.
i believe they are just polished. if you know someone who has access to a polisher (a looks like a bench grinder with a buffing wheel), that will do the trick. you may need to scuff sand or get some scotch brite and scuff them a bit.
if u where close to me, id buff them for you!
Walmart, home depot, lowes, any auto parts store....
It's near the primer and touch up paint.
The crowd here generally doesn't like to spend money, but if there is one of these near you I recommend giving them a try:
www.alloywheelrepairspecialist.com
They are franchises. Dude came here to fix a flat spot on one of the wheels on my son's car. Did a great job. Told me that most of his work is going around to used car lots and fixing dinged wheels on cars for sale. Has a whole shop in his trailer. They come to you.
I used aerosol paint stripper with a wire wheel. I then hit them with muriatic acid to clean the aluminum. I primed and painted mine from there. After you use the acid, you could use fine grit sand paper to bring the shine back. I have done a final sanding with 500 grit paper and then use Mother's Aluminum Polish to shine them up.
