Aisan 2 barrel carb vacuum setup?
Srtyourmom
I have a 88 ranger with a 2.0 and it's got a Aisan 2 barrel on it. Does anybody know how te vacuum lines are suppose to be setup? A buddy of mine took it off and Didn't mark which lines went where. Any help would be appreciated. My sticker on te truck is missing btw.:bawling:
Thanks
Matt
the sticker won't even help on that mess...in fact, you'll be hard pressed to find anything on the actual proper routing of those lines...even a Ford Tech couldn't figure mine out and spent a month in rehab for trying...
I tried to get mine working but ended up swapping out the entire carb and manifold for one from a Mustang II...much better and much less vac lines...if I had any pics of my old setup I'd post them, but I lost everything in a computer crash...
If you can find one in the junkyard you might be able to sort it out...so long as they haven't cannibalized it like most of the ones I found...
