Just to give you a brief explination of why it wont work switching, The MAP sensor reads manifold pressure, manifold pressure is always very close to 0 at wide open throttle, and will not change with RPM. They use the RPM as a key element in tuning a speed density system. Due to the fact that any time the computer sees 0 pressure from the MAP sensor, the signal never changes.
The mass air flow system uses the MAF sensor to actually calculate how much air is coming into the engine. The computer knows the RPM of the engine and uses it for ignition timing, but for fuel delivery they use mainly the throttle position, intake temp, and MAF reading. The MAF reading will change with engine speed at wide open throttle.
The only way to change the system over is to Put a newer ECU in, which doesnt work without the new sensors and wiring involved, or to reprogram the current ECU, along with some wiring. Both are not simple swaps.
