Airbag deployment 99 ford mustang
rkj606
I have a 1999 ford mustang, rolled into a tree, both airbags have deployed, now the car won't start.
Where should I start?
thanks
There is generally a fuel cutoff relay/switch in case of an impact. An impact strong enough to cause an airbag deploy probably tripped that relay. No fuel, no start.
A very general video
http://www.youtube.com/watch?v=WDfcSAFri_Q
I don't know particulars of your model/year. I read something about newer ones have the feature in the control so cycling the key does it. I don't know how far back that goes.
Off Google.
The fuel pump shut-off switch is located on the left side of the trunk between the left rear tail light and the trunk liner, and to the left of the hole in the trunk liner. If you are unable to access the switch through the hole, loosen the trunk liner near the switch by removing the cargo net hook and pulling the liner forward to expose the switch.
Sent from my XT1058 using Tapatalk
