Airbag dash light blinking
Pablorapido
Good afternoon, this airbag concerns a friends 1996 Explorer. After starting the vehicle the airbag light blinks intermittenly while the vehicle is in use. He was wondering if this was dangerous or if it is a sensor etc. I live in Mexico and it is difficult to get these type of things checked and fixed. Thank you all for any help you can give. It is a 2 wheel drive Explorer. Gracias, thank you Pablo
ford offered to fix the same in the f-250 work truck i drive,bad sensor they said.wanted like $150.i live with the light being on.
This happens to my 02 Ranger periodically. The first time it was repaired under warranty. When it came back a year later I just disconnected the connector under the seat that goes to the seat belt. I clean it with an electrical contact cleaner that has a corrosion inhibitor in it then connect and disconnect it a few times to wear through the oxidation. That takes care of the problem for about a year. In my case it is the passenger side but I think it can happen on the driver side also.
I don't know if the Explorer has the same system but it can't hurt to take a look.
Does anybody know if the blinking indicates which sensor is having issues?
In my 95 Ranger 4.0L the air bag light will flash twice then once and it will do this three times before staying on solid everytime I drive. (It could be flashing once then twice, I've grown to ignore it lately)
if you have access to a ford tech all you need to do is count the sequence of the blinks and tell them. they can look it up for you and tell you what it is. the light should give you 3 sequences of blinks. this happened to my 03 my brother is a ford tech and it was the one under the seat. i just unplugged it and plugged it back in and it went away. if the light stays on the airbag will not deploy when it is needed, so i would get it checked out.
