OilPatch197
- Sep 23, 2007
- Age
- 96
- Automatic
When adjusting for a tool on the regulator, do you adjust off of static pressure or dynamic pressure? Most tools run efficiently at 90psi.
Do you set the psi on the reg. while the tool is at rest, or at WOT? I've always set it with the tool at rest.
I did find one article that said to adjust the reg. while tool is running at WOT. Now this would result in quite a bit more pressure incoming to the tool while at rest.
