air bubbles
easyeric
so-cal...very so cal.10 miles from mex.
have a 89 ranger w/2.9-auto-4x4...when truck has been running awhile stutters and dies. when i check the fuel rail it sprays air and fuel(i know supposed to have 30 or 40 pounds pressure)if i hook up a hose on th schrader valve it bubbles air/little fuel for several minutes after key is shut off.then will start up and run a while longer.changed fuel filter,put new hose above the pump in the tank,put new fpr,help....please...e
