- Aug 6, 2007
- Age
- 37
- Caledonia, Ontario
- Automatic
First thing first, doner is a 93 thunderbird
k, ive dove head first into the engine control computer harness.... but its nothing like i expected. Theres 2 connectors near the computer connector. Ones got a bunch of power wires, i kindda shurged that one off as its probably just something for the interior coming threw the same harness and grommet.
But the other one really worries me. Its got the VSS wires going directly from the computer to this connector. Also its got a bunch of wires coming from the engine harness(the harness with the injectors). Most of those are temp sender, oil sender, that kind of stuff.
So far this is what i have found on that connector(numbers are the tags on the wires)
1 W/R Oil pressure sender
3 R/W Temp sender
4 PK/LG Check engine light
7 DG/W VSS +
8 G/R VSS -
9 W/PK Dash Tac Signal
GY/R
DG/W
T/LG(goes to the diag connector then has another thats the same colour attached in the same place going to the computer)
LB/PK "Data output line (fuel flow)" i assume that means gas gauge?
O/W "programable ride control output"
P Somthing for the compressor
Those are most of the wires on there, is there some kind of module that all this crap goes too? should i try to get it? can i leave it out?
Its mostly the VSS, the diagnostic connector wire, and the fuel flow ones that worry me.
Thanx
3 R/W Temp sender
7 DG/W VSS +
8 G/R VSS -
GY/R
DG/W
Thanx
