Aggravating issue....revisited...
rusty ol ranger
2.9 Mafia-Don
Michigan
2.9 V6
A legend to the old man, a hero to the child...
Heres the original thread....so i dont have to type the whole thing again...
Anyways....one suggestion that came up was the fuel filter, which i did change but it was when it still had the old fuel tank in it so who knows what got sucked up into it.
Well when i changed the filter before the line was stuck on the filter and when i pulled it all came apart.
So i had my mechanic put a new line on....and he used this...
Could that 90* bend be causing the issues im having?
It shouldn't.
Odd question.... whens the last time you tossed a tfi at it?
Also, still running the ecm i sent your way?
When i did the distributor....so a year ago or so.
....and yes its got your ecm in it.
I was reading the original post and this stood out, you said if it turn it off it runs ok for a couple of minutes.
So maybe it runs fine off the open loop ECM map but when it goes closed loop you have the problem. That would point to a sensor issue.
Every sensor besides the TPS and MAP is new. Its getting 21-22mpg so i dont think its an O2 or something dicked up. After talking to @PetroleumJunkie412 the other day i realized that it didnt do this before i timed it and deleted the EGR.
So im gonna recheck the timing and properly block off EGR before i go to crazy into it.
