bmacsys
Should I just swap between front and rear or should I swap right rear passenger with front driver side and vice versa? Thank you.
I move the fronts straight to the rear and cross the rears to the front. I think. Whatever the owners manual says.
If your tires are directional (arrows in the sidewall) then you can only rotate front to rear on the same side.
