- Jan 10, 2023
- Canyon Lake, TX
- State - Country
- TX - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 3.0 V6
- Automatic
- Tire Size
- 275/75R15
Been planning on V8 swapping my Ranger, initially going for a 302, but have shifted to a 351w. Planning to do mild performance modifications(aluminum heads, upper/lower intake, cam, headers, dual H-pipe), targeting ~300hp at the wheels(est 375hp at the crank, assuming 20% loss in efficiency of drivetrain), staying 4x2, Explorer front accessory drive, upgraded internals 4R70W, Explorer 8.8 with Eaton TrueTrack (3.73) swapped in. While I've realized that I may have been a bit focused on the engine, preparing the transmission for accepting the higher amount of power, swapping springs to stronger springs(eg Ranger HD leaf springs), adding a traction control spring and rear sway bar(not one from the factory)... I'm finding my mind turning to the frame. Does anyone have any advice on what my options are, and the pros and cons of these different options might be? Focus of the power band is going to be low end/mid range torque over top end HP, trying to give some improvements to the capabilities of the truck, mostly on road with some light off road usage here in the Texas Hill Country.
Don't know how much it matters, but I do have coil springs in the front, not a torsion bar. 02 Ranger XLT w/2door ext cab, 125 wheelbase.
