Advice on a 96 3.0
mtnrgr
California
6" Skyjacker, with 1.5" coil spacers, custom radius arms, custom traction bars
31x10.50
Lord God is my guardian
Truck is moving forward to remove all parts, and leftovers will be scrapped.
Ok your question is a little confusing to me because to me it reads you want to use parts of a 2.3 wire harness on a 3.0. But you also said that your concern is using a 97 on a 96. If you are tearing apart one harness to fix another but one for a different engine there will already be major differences.
This is where I am just not understanding where your concern is. You already know that it's not a direct replacement so I'm confused.
To my knowledge the 96 and 97 3.0 motors were the same and the body/interior is the same so should be a direct swap.
98 huge difference 94 is a big difference also because of using the ecc iv computer, distributor system, and still the OBD 1 setup. 95 they changed over to DIS system on the 3.0 requiring the new engine management system.
