green lantern
- Dec 13, 2012
- Automatic
i need info on what water pump and pulleys to use on a 84 ranger 5.0 conversion. i have a 302(bored 0.20) roller motor (late 80's) completely rebuilt with comp cam, pistons etc... gt40p heads, edelbrock performer rpm intake, edelbrock 650cfm carb but i am not sure which water pump and pulleys to use. I have the stock water pump and serpentine belt setup. will it work? Or fit i should say? also still need to buy ignition or should i use dura spark 2 module and vac advance distributor out of 70's 302 being as I already have these parts? Also can I use the stock alternator that came on the 5.0 and power steering off the 5.0 being as they are already set up for the serpentine belt and i have these parts or do i need to use the v6 2.8 ps pump and alt?
