Advanced Adapter Headers
Broosedamoose
DaMoose is lose!
South East Massachusettes
31 x 10.5
Coming in second just makes you the first loser!
So according to customer support at Advanced Adapters, their V8 conversion headers will work for me where I am using the straight GT40 (not P) heads. Has anyone ever used them or know anything about them? They would be the 717044-HDR model.
picture.php
I just wonder about stuff in the way: steering rod, frame rails, etc. :dunno:
Yes they will work I used them on my 96 ranger 5.0L gt 40 swap I did run into two clearance issue tho on passenger side. To fit the exhaust clamp I cut and notched the header to turn toward the engine just enough to fit the u bolt. Also I recommend Alan wrench header bolts as I could not get the bolts they send tight due to a socket will not fit on the bolt on some exhaust ports. I tried posting pics it failed
I have an 03 4wd. I think some things changed in 2001.
Still would get a different set of header bolts due to fabrication of the headers.
