Advance Adapters for a 4R70W
Farmeyer
Douglas, Wyoming
Okay so what I have going on is Explorer 5.0 with a 4R70 AWD setup swapping into an 86 2.9 ranger. If at all possible id like to keep the newer transmission with the overdrive rather than going the C4/C5 combination route. Another thing is I have quite a few bw1350 transfer cases so id rather use them than finding a full size NP-205 or 208.
Now my question. From what I understand, most of Ford's full size transmissions have the same bolt pattern from them to the transfer cases, or so I have read. On the engine swap page it has a couple adapters listed from Advance Adapter's website but they claim its only for a manual 5-speed. Why couldn't a guy use one of these on a full size auto like the 4R70W? Any thoughts?
P/N 50-4501 - For 28-spline 4wd transmissions to Borg Warner 1350
P/N 50-4502 - For 31-spline 4wd transmissions to Borg Warner 1350
The 1350 will probably bolt right onto the Explorer trans. It will probably also look a lot like the one I tore apart for scrap tonight after one or two good romps on the throttle.
I don't know why you couldn't use a manual trans transfer case adapter on an auto. Get one, try it, tell us what does or doesn't work.
It won't work. Not even close.
If part-time 4x4 is what your after, you'll have to use a Borg Warner 4406 from an F-150.
