harriw
So when I bought my '94 4x4 (4.0 ext. cab w/ 5spd) back in the end of January, it already had Warn manual hubs installed up front, but needed new brakes and rotors. My brother-in-law got his shop at the dealership to do them essentially at cost for me, so i was good to go. Now, 9 months later, I just noticed that the wheel bearings are loose.
So, here's the question. How far do I need to/should I go? Can I get away with just pulling off the hubs and re-tightening the adjusting nuts? Or should I pull off the caliper and rotor, remove the bearings, clean 'em, re-grease 'em (or replace 'em if they're worn), put on new wheel seals, and re-assemble everything? For what it's worth, I hear no bearing noise what-so-ever, and the braking is great. There's just about 1/16th inch of wobble to the wheels (top-bottom and side-to-side) that I already confirmed is not due to the ball-joints/TRE's.
Final question if I tear it all down - after 9 months, do you think I'm OK re-installing the existing rotors and pads as-is, or should I get the rotors turned first, and/or get new pads as well?
Thanks!
-Bill
Thanks!
-Bill
