- Dec 3, 2016
- riverview, fl
- 2.9 V6
- Automatic
- Total Lift
- none but it is a convertible
- Tire Size
- stock
I am to the point of adding the ATF to the M5OD that I replaced the 44E with. Can I pour the atf down the hole where the shifter mounts? I will have to crawl under the truck to open up the fill hole but it sure would be easier to fill from the top, rather than lying under it with a hand pump
