Adding Fog Lamps to my 94
rumblecloud
5+ Year Member
⭐Supporting Member
MI - USA
Vehicle
1-1/2 inch front leveling
Stock
What's the worst that could happen?
For all you veterans out there, this is eezy-peezy --- I hate electrical things so this is a major endeavor for me.
Been collecting things for a bit to add lamps to my 94. Picked up the brackets from a TRS member last December. Got a switch from a 95 off eBay. Since the wiring is already there (94 Splash - I know they (Ford) only have one harness - maybe 2), I dint think it would be a big deal. So far I'm right.
The valance I can get from a number places as well as the lights - ($30 and $90 respectively). They'll be ordered shortly...in the meantime...
I've been playing with the switch wiring, comparing the 94 to the 95. Coloring is different, but it seems simple. So far I get the switch to light up. Since I don't have the actual lights yet, I won't know for sure, but so far, I think I'm ok. I'm almost thinking this is too dumb to post, but then I remembered this is TRS.... thank you:yahoo:
See if you are getting 12 volts at the fog light connectors.
Nope. Not getting 12. Will be playing with wires later.
Is the relay installed?
EDIT: It doesn't help if I've worn the battey down to 11V either...
Thanks for your response. However, you oughtta be taking it easy instead dickin' with my stupid issue.
Yes, Relay is there.. I have an extra.
The original wiring has been there hanging out since 94, so I am not surprised. And of course I may have my hodgepodge wiring at the switch crossed up.
Functionality is simple I guess. They only receive power when ignition is on and low beams are powered. They go off when high beams are activated. The light in the switch comes on when the ignition is on and low beams are activated. Depressing the fog lamp switch at that point changes nothing - as far as voltage to the outlet plug goes (if that makes any sense. Not having the fog lamps to actually see what's going doesn't help either.
I am getting millivolts(?) at the outlet plug - nowhere near 12V though. I'll keep playin with it later.
Take it easy. and thanks again.
At this point, I'm just laying on a bed getting stuck with needles, poppin pills and being hooked up to monitors. It's not complicated as the patient.
Pull the relay out.
Use a piece of wire or paperclip o short pins 30 and 87 to each other.
Do you have battery voltage at the fog light plugs? If so, good.
If not, see if you have battery voltage on pin 30. If not, check fuse in underhood fuse/relay panel.
If you do, make sure grou d side of relay is connected to clean, tight ground.
Otherwise, with key on, lowbeams in and fog switch on, or whateber the conditions need to be, you should have battery voltage to 85. If not, check all thpse things and the interior fuse.
Hey CH...I had a chance today/night to do the checks you suggested and am putting together a little list of what I found. Sorry it has taken so long, but, poo happens.
Take care.
r
Update:
We have power to the fog lamp plugs.
Went thru the checks provided by Curious Hound in the sequence he suggested. Only had power to pin 30. Checked fuses and there wasn't one in the underhood box for the lamps. Did a couple of other things, like cleaning up the contacts and such and now I have batt voltage at the plugs. Next I have to order the lamps and the valance as soon as the CFO approves the purchase request. :p
Thank you all.
Parts ordered. Mounting the switch now and making the final wire connections solid now that I have them in the right order.
Valance came in Tuesday - folded. So it's straightening itself out in the basement next to the furnace. I helped it out a lot with a hair dryer. It's coming along. Fogs came in today so I did a quick test. Soldering is done. Switch works. Trying to decide if I want to repaint a portion of the front panel. The radio side is kinda messed up.
Adding Fog Lamps to my 94 Adding Fog Lamps to my 94 Adding Fog Lamps to my 94 Adding Fog Lamps to my 94
