spin
- Jan 25, 2011
My B2300 didn't come with a tilt steering wheel or cruise. I added a tilt wheel from a 1996 mountaineer. All the connectors under the hood are there for the cruise. I put the 4.0 servo under the hood and swapped the cable from a v8 crown vic. I had to do some fabbing to the cable to make it hook up to the throttle linkage. I also added the connector for the master cylinder. The cruise doesn't work. What else do I need to do. Is there a computer somewhere that needs upgraded? Is it because the 4.0 servo was used (electrical connector looks identical)?
