STPL
What's the acceptable amount of play allowed in the tie rods/tie rod ends? I just removed, rebuilt and replaced my steering box and changed out both tie rod ends connecting to either wheel. Now when I grab the long tie rod running from the pitman arm to the passengers side tie rod end and twist it so the two top and one bottom passengers side tie rod ends pivot full range. How tight should these be? If I tighten the castle nuts on the tie rod ends will it lessen the amount of play in the upper tie rod ends, or do these need replacing? I replaced the tie rod ends hoping to cure a terrible clunking going over pot holes but it didn't fix anything. See video for further details: https://vid.me/lHTiD
