2001FORDRANGER
Hey I took my car into Econo Lube today as I know the owner. he test the entire system which took about an hour. After he saids all is fine and gave me a check list that shows all is fine. He said he had to manually start the compressure becuase it was getting no power to it and he does not know why.
So my question is everything is fine except it blows but not cold air. I checked my swith which I found two of them. I figure that one or both is bad. could tjis be correct. Please advice. I need you guys help as I already check the control switch in the cab and all is fine. thks
