Racenut
- Jan 1, 2013
This is on a 86 b2 with a 2.9.
Trying to fix the AC. The compressor went out in it last year. Got a new dryer, orifice tube, and a remanned compressor. Put all on today. Pulled a vacuum, put one can of 134 in. Compressor started to cycle, but pressure is showing too high when compressor is not cycling. Compressor wont stay on . Pressure drops when compressor is on and then it turns off. I see some metal shavings between the pully and the outside clutch plate. Does this mean the compressor is bad?
Why is the pressure too high after only one can when the compressor is not cycling?
Thanks
Thanks
