ac clutch on with key off
jimsea
Have 03 ranger 4x4 and when I went out this morn, batt was dead
charged batt and noticed that when I disconnected the ground on the batt
the a/c clutch disconnected. I connected the ground and pulled the fuse
and then the clutch disconnected, reinstalled fuse and disconnected the a/c switch but the clutch stayed connected, I pulled the a/c solenoid and the clutch still stayed connected, I have pulled the fuse so the batt will not run
down I do not have a diagram anyone had this problem?
Thanks Jim
a/c clutch on with key off
OK I got it
I had pulled the wrong solenoid. Pulled the right one and everything worked
I used the solenoid for the fog lights until I can get a new one.
Thanks again
Jim
