ABS Wheel Speed Sensor removal
Eaglefixer
How does the right front sensor come out on my 96 Ranger. I have remove the bolt but can't get it out. Is there a trick so i don't tear it up? I'm in the middle of trying to change my ball joints so any tip there would help alot
After you take out the bolt it should tap out its just held in with friction
Well i couldn't get the passenger side off so i just disconnected the wire harness. So now i get to the drivers side and it just sides right out after removing the bolt. Just got done changing both my upper and lower ball joints. Also changed my wheel bearings and brake pads. Just got to finish the drivers side now. Backs killing me now so i'm taking a break. Thanks for the Reply
