1badfox
- Aug 21, 2013
- Automatic
Hey guys I recently picked up a clean 00 ranger that has been 5.0 swapped. I'm a perfectionist so naturally I'd like to get the truck in perfect mechanical condition before I add any aftermarket parts.
Here's what I know. 2000 ranger 2wd, 99 explorer 5.0 2wd donor vehicle. It runs and drives great but I've got a few CEL's I'm trying to correct. The biggest ones being the ABS system and VSS codes. The EVAP code should be an easy fix so I'm not to worried about that one.
Here are the codes that a present.
C1155 left front speed sensor(VSS)
C1145 right front speed sensor(VSS)
C1230 rear speed sensor(VSS)
P0500 speed sensor A- VSS is not reading
C1095 hydraulic pump motor(ABS MODULE)
P078 transmission range sensor A
P0453 EVAP sensor high input switch- probably FTP needs replaced
P1000-not worried about this one
P1729 4x4 low trans fault?? I DON'T HAVE 4x4 so WTF?
So now for the questions. How do I get rid of the C1095 code? Someone removed the abs pump/ lines from the explorer abs assembly and plugged in the electronics only. In photo below.
Next question. Are the explorer front speed sensors something g that I can install on my 00 ranger? To possibly correct those codes?
And why would I have a p1729 4x4 trans fault? Both the ranger and explorer were 2wd.
