Hetzi
I replaced all rotors, pads, and bearings on my 2011 Ranger 4x2. After doing that I got an ABS-Traction Control light on. Scanned it and says C1296 left front sensor fault. Replaced that sensor 3 times. Light still on. Thought tone ring on the rotor may be not right, replaced rotor. Light still on. Thought maybe wheel bearing and torque play wrong, replaced bearing again, torqued nut to spec. Light still on. Light stays off under 55mph. Over that comes on. Checked continuity on harness, OK. Thought that ABS module was the final problem. Replaced that. Light still on. Any thoughts of this problem?
