ABS light/seedo bounce 1999 ranger
kburley
southern ontario
Hi guys, got a fresh new problem to deal with. I have a 1999 ford ranger xl, single cab rear wheel drive. yesterday my abs light came on and my speedometer started to bounce. It engages around 60 km/h when accelerating, and when braking it will bounce down to zero once I go below approximately 50.
I did some research and came to the conclusion that it must be the vehicle speed sensor, but on my way to NAPA to get the sensor I thought I'd break out the scanner to be sure that the same code I had researched would be read in my truck (I think it's p0500? or something along those lines). I was surprised to find no failure codes to speak of. I spoke to a friend and he thinks its the cluster, and that's why the speedometer doesn't work, but that doesn't explain the abs light. I figured before I go ahead and replace the sensor anyway I would ask if anyone knows what's going on. I would hate to get a new sensor and not have it fix the problem. Does anyone have an idea of what's going on? Any and all input is greatly appreciated.
Thanks!
rear abs sensor in the rear axle. very simple to get to. on 98-00 rangers that reads abs/ and vss
