LoneRanger93
- Aug 10, 2007
- Age
- 39
Before I make a trip to the shop to get the code run I wanted to check some of the contacts to make sure everything is hooked up correctly, in addition to the fuse panel, brake fluid reservoir connection, and the plug underneath the driver seat under the cab, is there any other connections I should check?
