Kdunne910
2000 ranger xlt 6 cylinder 3.0 2wd.
so it all started with an easy axle shaft seal replacement. after i get done with that i notice my brake drum was not fitting on the right way. so after playing with some stuff and replacing the brake wheel cylinder the brake lines and the parking brake cable(the cable was causing the problem) i finally get everything back together and working the right way. so i go for a drive and everything seems to be fine. few hours later i leave again and now my abs light is on and my cruse control is not working..
what do??
what do??
