greg1459
- Jul 15, 2008
- Age
- 43
I have a 95 Ranger 4X4 and both the ABS and Brake Lights are on. My problem started when I changed the bearings and rotors out. It started out only as a slight shaking in the front end when I applied the brakes. After a while the vibration became worse and the brake light came on. The next day the abs light came on and now the pedal is really soft. The brakes occasionally lock up.
I went in and checked the front ABS sensors and found the one on the drivers side torn up. It looked like it had been in contact with the ring on the back of the rotor.
I know I need to replace the sensor, but I have a few questions first. I suspect that I may have overtightened the Hub nuts. My first time removing them and I know I did not use a torque wrench. What do you think? Could over tightening the hub nuts push the rotor back far enough to contact the speed sensor? If so, how can I prevent this?
Also what type of bolt is it that holds the speed sensor in? It looks a bit like a torx but with more ridges. I can't seem to find anything to fit it.
