A4OD FLUID correction A4LD*
gaz
Wa, Bremerton 98310
Ranger 5" (1½" Hiryder/3" body), BII 4" Procomp
Total Drop
Ranger 5sp, BII A4LD
Ranger 32"/4:10LS, BII 33"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
Hello,
Things used to be simpler, everything is always being improved.
I'm considering using Castrol Transmax ATF in my 94 A4OD (A4LD*). I used to simply walk to the NEX garage from the MWR hobby shop and grab up Mercon IV, V or the current improved formula. Hobby shop closed, very slim pickings at the NEX garage.
The label states that it is compatible with Ford Mercon multi-purpose ATF; is their any reason not to use it in the A4OD (A4LD*)?
Assuming A4LD, any fluid that has a Dexron/Mercon spec should be fine. I usually default to Maxlife on everything I service now.
@Mechrick
Thank you for catching my error(s) and answering my question ..)
