Buhz
- Jan 21, 2013
- Automatic
I bought a 94 XLT 2wd from a friend that had an over heated transmission in it. 3.0 engine w/ an A4LD automatic. I took it to a shop and had it rebuilt. The shop called and said they thought a part of the wiring harness was missing. The wiring harness from the tranny has 2 leads coming up, One plugs into the firewall, Both plugs are round. The smaller round bullet plug has an orange/yellow wire and a purple/yellow wire on it. There seems to be no place near the end to plug into. I am thinking maybe the transmission had been swapped at some time? There is a larger round connector up near the front of the engine but isn't long enough to reach. The wires on it are Green/white? and purple/ yellow. went to the local ford dealer and got a copy of the wiring harness, It appears to have a few changes in it though according to the truck wiring. Any ideas how I hook this up? The wires in question are for the Solenoid for the OD maybe? I'll have to talk to the Shop again to confirm. I went to the local LKQ and had zero luck w/ a new harness. I had read on here that some have 2 wires and some have 3 wires. Unsure as to how to hook this up. Any help is appreciated. Thanks in advance
