Syko
- Apr 11, 2008
- Age
- 36
1987 B2.. previous owner did the swap but didnt do the wiring (so im a bit lost) for the reverse lights, Auto 13-50 TC(4hi works 4low doesnt), and the NSS.. i found this
AUTO transfer case- put the shift boot on. Go under and cut the 5 wire plug you will be using all of these wires. Put the red/blue stripe and red/yellow stripe to the Blue with black stripe running to trany. next would be the wht/pink stripe to the blue line running to the tranny. this will let the truck start and shift to four low with tranny in neutral. next match the wires for the back up lites they are the same color coming from the trainy should be like a purple color. IGNORE THE TWO WIRE PLUG this is for the torque converter lockup
here:http://www.therangerstation.com/forums/showthread.php?p=242
But i am still some what confused if anyone would like to help me out a bit i would be greatful
Thanks Syko
Thanks Syko
