- Aug 26, 2008
- Automatic
- My credo
- Failing is easy. Everyone can do it.
Well, as the title states. Driving around today and noticed each time I had to back up? It took just a touch longer for it to engage. Got to my base store, and tried reverse (figure close to home if it crapped). Took about 20 seconds, found reverse...and it went in reverse, all the while I could hear it starting to slip.
Thankfully all the forward gears are still functional, although I have noticed it's starting to surge a bit going into 3rd gear. Still makes it, and that gear is not slipping that I can tell. (I more or less backed it into the parking space, put 'er into reverse, let it find reverse...and it's a slight incline, so gravity helped) When it's stone cold? It works 100% normally. Get it bakin' after a long drive? And that's when the fun starts. (bakin' is an operative term, as there is a large external cooler in front of the radiator, so I know it's not overheating)
I've got our local truck salvage yard lined up for Friday afternoon to pickup another A4LD for $250. Minus the transfer case, so I'll need to swap the dummy case over to the A4LD.
Changing to manual isn't an option for me, as I have a bum knee and can only drive standard if I'm really really in more of a prone position (otherwise my knee buckles)
Asking for general tips and hints. Any ideas on changing out the transfer case/tips/etc...and changing out the A4LD in general. I've changed transmissions in the past, but any words of wisdom will be helpful. Planning on driving the ol' girl locally for the next two days, and it goes in our family garage (no lift, but heated) Saturday afternoon and Sunday for the work.
Posting here and a few other places hopefully to get the most advice I can.
Thanks!
S-
Thanks!
S-
