A4LD swap out problems help
stfree
Costa Rica
My old '90 4.0 4X4 Ranger was having shifting issues that forcasted failure of the A4LD in the near future. Some months ago, a friend had his '92 Explorer come to a untimely end to when a fuel leak resulted in a fire in the engine compartment. His truck was running and shifting just fine at the time of the fire and the transmission was unaffected. That tranny had a full rebuild about 8 months before using the new design upgrade parts for the A4LD.
I made a deal with him for that A4LD transmission and transfer case and pulled it about four months ago to have it on hand to replace mine. I finally got around to swapping them this week. It appeared to be a one for one swap and went without a hitch. We have everything buttoned back up but there is no joy. No motion at all, forward - reverse - nada. Dash indications for 4X4 and "low" are seemingly correct. Fluid level is correct and clean as a new.
Can anyone offer suggestions as to what we obviously missed? It's hard to believe that the donor transmission went bad sitting on my shop floor.
No Movement,,,
I would ask if when doing the swap and putting new trans in, did you MAKE SURE BEYOND A DOUBT, that the TC was on and spin it and push it in again to make it all line up nice and tight,, ? If you went under truck to install or if you pulled motor and then install as one ? If you go under truck and you dont pay very close attention and make sure TC stays put exactly where it needs to stay, that can cause issues as you describe.
