A4ld rebuild issue
NaomiTheNomad
Forum Member
Florida
I posted in the wrong thread first time around lol. So this was my first solo rebuild on a 94 A4ld in a 4.0 2wd ranger. Transmissiom failed due to overheating, so i got the truck for dirt cheap with a new motor, anyway, transmission is in. I drove it last night, i have all gears, i can reverse and drive. however when driving it wont shift into the next gear, funny, it shifts but don't right!? There is a few things ill look at later, i believe i did overfill it, i thought it took 9-10 quarts but warm and idling i check the dipstick and its about an inch above the crosshatch. front seal seems to be leaking too, so ill probably have to pull it anyway to do that and check my busching and TQ again for anything i missed, unless its purging any excess fluid.
seal seems to only leak at park ,idling, ill also test that again today because it was dark last night, i took it for a 10 mile drive before i knew this stuff, tired as hell and realized my rpms were staying stuck and it wasnt shifting. Ill pull the modulator line to see if there is atf anywhere, i did smell something burning however this was my first time i could drive it and its straight piped with a massive exhaust leak from a header so i thought it was that. All bands are adjusted correctly, i double checked. Any pointers here asides what my common sense says? Overfill is messing with it or the modulator? There was no weird sounds or jerks. Im not in a rush to get it running properly, so im willing to pull it again, was still worth the drive last night, even if it was a short one.
Overfilling can mess it up. The fluid will get up into the rotating parts and get stirred up and all foamy. The fluid won't do it's job and make things work if it's just a foamy mess.
very true, thats why im a bit thankful of that leak to take care of it, i dont expect this transmisson to last real long since its a first build, even though i was thorough with everything im sure there has to be one thing in it thats not right. In the near future me and my buddy want to manual swap it. I wanted a chance first to drive it a little and fix up any tweaks the engine has, at the end of the day i can say i rebuilt an auto and it worked for a bit but time will tell what happens, all i can do now is take care of it.
If you have a glass quart canning jar around with a lid and some tubing that will fit down into the trans dipstick tube, you can cut two holes in the lid so the tubing fits tight.
One piece of tubing is long and goes down to the bottom of the jar, goes through the lid and all the way down the dipstick tube to the trans oil pan.
The other piece of tubing is also stuck through the other hole in the lid, but it only goes into the jar a little ways and stops up high in the jar. The other end of this tubing is slipped over a nipple on the engine somewhere that has manifold vacuum.
Start the engine, the engine vacuum will start sucking the trans fluid out of the trans, filling the jar up. Stop the engine before the fluid gets high enough to get into the vacuum tubing, and then see where you are at and repeat as many times as needed. I would save the fluid, that stuff is getting expensive.
Same method i use to bleed brakes and clutch lines.
