- Aug 26, 2008
- Automatic
- My credo
- Failing is easy. Everyone can do it.
Another fun day it seems.
Driving back from Utica home (about 60 miles) we noted blue smoke...figured engine problems. Got back into the area and checked the oil--still good? Went to leave the pizza shop we stopped off at for dinner...no drive? So I put 'er back into park, back into drive--and it went right into gear. Got home with no problems---checked the transmission fluid--not even on the dippystick. Next day added fluid to bring it up, and it "foamed" the fluid...and slipped in first gear.
So I'm thinking "Great, blew a front seal..and toasted the transmission". Limped it over to the family shop--and it drove/shifted flawless!?!?! after putting it from park into drive again. Dropped the pan, just the usual crud build up in the bottom. Filter looked great. Pulled the torque converter? Severe score mark on the 'snout'--
So we purchased a rebuilt converter figuring the old was had to be out of balance (we did have a 'worable' sound for a while) I remembered reading about pilot bushing in the flexplate taking out the front seal and damaging the front bushing. Sure enough? The pilot 'bearing' is egg-shaped.
So here's the plan, considering the transmission we are working with does NOT show signs of internal carnage from being driven low on fluid (very very lucky in that respect).
Have a new pump to bellhousing seal on the way. Due to the severe score on the snout of the torque converter, it's a safe bet the bushing has been damaged.
We have the orginal A4LD still in the garage awaiting a rebuild. It went south due to valve body issues and slippage. I'm planning in pulling the pump/bell housing, cleaning it...and inspecting it. Planning on installing that bellhousing/pump onto the other transmission. That should deal with the bushing damage (as the bushing sits in the bell housing) (yeah..I hope the pump is in good shape)
New spacer for the end of the crankshaft is also on the way (Dealership item...actually only $32 bucks).
So we are going to swap bell housings....use the new torque converter...replace the spacer with the pilot bushing...and hope everything works.
S-
S-
