A4LD floor shifter
svtcards
Lyman
ME - USA
Other
1987 Ford bronco ii 2wd
Vehicle
Drive
2WD
Total Drop
3'' front 4''back
Hi. im in the process on putting a 4.0l into my 87 ranger.the donor is a 1991 ranger 4x4 with the 4ALD trans.now my question is what do people use for a floor shifter since hurst and b&m don't make a floor shifter for it.not sure if the 2.8 2.9 bronco 2s had this trans in it with a floor shifter.any help will be appreciated.
The A4LD was around in 1985, the Bronco 2 and Ranger both had floor shifters, so you just have to find either truck and get the original shifter assembly.
Thats kinda what i was thinking as well.A4ld bolted up to the 2.8 and 2.9 rangers also to then.i wasn't sure for sure about until now.thanx for the quick response.will start the search ASAP
