Jim2
My truck hesitates when I punch it @ idle... it's just for a split second, and then she revs clean to the top end after that.
Also, it backfires once every time I let off the gas for the corners (from redline).
This truck is only for the track, so I don't care about MPG at all.
The track out here is a small, it's a dirt-rally course.
Top speed is never a factor over there, but 0-45 is everything.. so I would trade some top end power for more low end response.
So anyway, here's some more info about it.
-The exhaust ain't stock.. it measures 2-1/2" O.D. at the tailpipe, but I cut it off right after the muffler. The I.D. is 1-7/8" at the bend where I cut it, and there's no catalytic converter.
-It has headers, but I don't know what kind/brand.
-Has an "Accel" ignition box.
-Has what looks like a "K&N" style air filter. (It's kinda dirty, but even when it's removed, the miss is still there)
-I installed a stronger fuel pump in the tank. I guess the inline pump is stock.
-I just replaced the heads and set the valves.
-The fan clutch is jammed up. There's no clutch action. It's like a solid link there..
If anyone can offer some tuning advice, I'd really appreciate it.
I'm a carpenter, so I don't know too much about tuning... but I'm tempted to advance the timing a little more..
