Ho Shorts
- Dec 19, 2009
- Automatic
Hello, First off thanks for taking the time to read this as I hope I put it in the correct section. I am nearing completeion of my wife's truck (1972 Ford F100 Shortbed 2wd) and just have a few decisions to make that I have been putting off until last. The truck has a 3.70 rear end ratio in it and came with a 2 barrel 302 and 3 speed on the column. I removed said engine and tranny as the engine was shot and the 3 speed with that rear end ratio was turning the motor a little over 3 thousand at just 60 mph. Not good enough for the area we live in as occasionally we do need to interstate drive. I have purchased an AOD automatic transmission and have just finished putting together a fresh 300 six cylinder engine (81 model engine). I have purchased an offenhauser 6019 Dual Plane 4 barrel intake for said engine and the Hooker header with dual exaust setup. I am going to run dual 2 1/4 inch pipes with two quiet mufflers (the truck had a glasspack when we bought it and sounded horrible).
My question is does anyone have a reccomendation as to a carb size? The only other truck I have in this model range is my one ton which has a 390 big block so nothing to compare to. (If it were up to me this one would have another 390 as well, but she wanted economical).
I have been steered to a 600 cfm Holley square bore carberuator which sounds big to me considering I run a 650 double pumper on my 390. Keep in mind this is a bone stock except it has been bored .030 over 300 six cylinder. Is the square bore carb in 600 cfm's a good choice? I'm looking for economy over power on this project as it is strictly for weekend cruising. Any thoughts or tech advise would be greatly appreciated as carbs are over $300 each and I want to be happy with my purchase.
Thanks,
Derek
Thanks,
Derek
