JakePSD
I have a few issues with my truck that i wanna know how to fix. First off, when its warmer outside, cruising about 55 to 60 mph i get some pinging, almost sounds like a diesel, only quiet. I give it more pedal or let off and it goes away til i get cruising again. Why is it doing that and how do i fix it? I have new autolite platinum plugs, wires, and coil packs.
I also have a bit of a miss at idle.
Also when i first start it after its been sitting for a few hours i get a rapid ticking for a second or so.
Not related to the engine but my headlights SUCK. High beams are about the same brightness as my super duty's low beams. I have new silverstar bulbs in it. Relay not making good contact maybe?
Also i need to know what years of rear leaf springs will bolt in. Mine are shot, i had to weld together the circle part around the front hanger. I wanna get that fixed. Also can i flip the shackle to level out the rear? I wanna drop the back just a bit to level it.
