ThatOneGuy
- Jul 23, 2017
- South sound
- 4.0 V6
- Tire Size
- 235/75/15
- My credo
- Let the universe take you where it will !!!
First question
Does anyone know if a first gen clutch master cylinder has the ability to properly actuate the slave cylinder of an m50d, or do I need to use the 93 master cylinder.
Second question
I am going to be swaping in an 8.8 l.s. disk brake axle. If I were to use a 98 expo brake master cylinder, can I use the 83 brake booster, or can I use a 91 booster, or does the booster also need to be from a rear disk expo. I know I could use the 83 brake booster and master, but it would cause excelerated rear pad wear, however I would like to run the correct parts if it's possible. The other question is if I use the latter disk brake booster and master does anyone know if it's direct bolt in. I've read alot of articles, and posts. But these are some points that were either not too clear or I forgot. It's been alot trying to prepare for this swap. I'm hoping to have everything ready by the time the block is done.
Second question
