Hey all,
I have a 1990 2.9 Ranger, which I've been enjoying a lot. Picked it up with only 185,000km on the ticker, and the body is in pretty good shape (for where I live anyway).
It's already had the leaking valve cover seals replaced (by a garage), and other than that I've just done really basic stuff like change the transmission fluid and oil.
I've always liked cars, but never really worked on them which was one of the reasons for this truck. I wanted to be able to have a vehicle I can learn on.
I'm wanting to refresh some parts, and one of the parts I wanted to put on is an O2 sensor.
But, I noticed on RockAuto that there's 3 and 4 wire sensors. It's the middle of winter here so I haven't crawled under the truck yet, but what should I look for on the current O2 sensor? Will I be able to see 3 or 4 wires coming out of it? I'd rather not pull it off if possible, as this is my daily.
Also, I was going to put new plug wires on as some of the current ones are pretty hashed. I saw it wasn't too much more money for wires and a cap+rotor, so I was thinking of doing it all at once.
Question is, I've heard changing the cap+rotor can change the timing. Is there a way to replace a cap+rotor without having to re-time the engine?
Finally, a question about cleaning.
Previous owner drove a long time with leaking valve cover seals, so the engine, engine bay, and transmission are covered in old oil. I tried some Gunk engine cleaner in the summer, and it didn't do much. What's a safe way to give this engine bay a deep-clean, or should I let a pro do it?
Thanks in advance.
Thanks in advance.
