ironman86
I seem to have a problem with my A/C. Here's what happened... I was driving down the highway at about 70mph when I needed to pass another vehicle, so I accelerate, and when I do so, the air stopped blowing from the vents and starting blowing out of the defrost. As soon as I let off the gas, the air started blowing out of the vents again. The A/C control is set to MAX AC. Now, I'm assuming that there is a vacuum leak somewhere which is what is causing the air to blow out of the defrost when I accelerate instead of it blowing from the vents.
Now, my question is, where do I look for this vacuum leak? Where could the vacuum leak be that would case this sort of problem? Is there anything else that could be wrong, causing this problem? Thanks for everyone's help.
