A/C - Heater Fan Doesn't Work on 2 Lowest Settings
fastpitchfan
Almost a year ago, I noticed the A/C - Heater fan in my 94 Ranger didn't seem to blow as hard on MAX A/C as I remembered. I checked here and found a post about the resistor. It was a very easy job, but it didn't make a difference after it was installed. I figured it was just my memory, because I had moved to Florida from the central coast of California where I hadn't used my A/C on Max for awhile.
Anyway, several weeks ago, I noticed the first setting on the fan didn't seem to work at all. I still had the next three settings, so I figured I'd be OK. On Monday, I noticed the fan didn't work on the second setting.
I'm now down to just the last two settings. I'm thinking about installing a new resistor, since it's both easy and cheap. I saw a post here about a relay located behind the passenger side headlight, but couldn't find it. Anybody have an idea where it's at on a 94? I've also seen posts here about the fan selector switch. How hard is it to get to and replace?
Any help will be appreciated and if anybody knows anything else I can replace, please let me know.
By the way, the article mentioned the resistor being a dealer-only item....I was able to pick one up at Advance Auto for $18.99 & tax.
