A/C compressor won't come on
jjramirez
I have a 94 ranger and the a/c quit blowing cool air. the clutch was running and I put Freon and it was cool for one day. Now the A/C clutch is not coming on. The compressor is only 18 months old. I checked the a/c 10 amp fuse and it is not blown. Any suggestions before I take it in and they tell me the compressor is no good.
check your ac pressures, if its not to proper level it will not let the compressor turn on
A/c compressor
Well, it was running and I put 2 cans of freon in it and the next day the compressor was not running, so I was wondering if there is a fuse besides the 10 amp ac fuse somewhere else.
ya what F.O.R. said did you use a gauge set when you added it could be overcharged too
ranger a/c compressor
The can had a built it gage, it was in the safe mode after filling with freon.
ohhh lord one of those. You cannot properly fill a a/c system with just a can or even gauges. It could still be underfilled or overfilled, you need to get it evac and recharge with a machine that measures the wieght
