A/C Comp
Twister
Omaha, Ne
Ok so i have an 85 BII, my a/c doesn't work. I have recently come into several cans of freon. Is there anyway i can test my ac compressor?
Thanks in advance and sorry if this question has been asked several time before, i could not find a thread asking the same question.
just jumper power to the wire of the compressor and see if it clicks. then take it to a SHOP and get it leak checked and charged.
its illegal to charge/discharge R-12 without a license. and its illegal to charge R-12 into a known leaking system
R-12 (if that's what your cans are) is only becoming more scarce. Definitely do not try to charge it without having it thoroughly leak-tested first (the fact it's not working now indicates for sure there's some sort of an issue with it).
If what you have is R-134a, then the system will need to be flushed and converted first (in addition to leak checking) before you can use it.
Strongly recommended you take it to a shop no matter what if you're not fully familiar with what's required.
